Ga door naar hoofdinhoud
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
Where to find replacement gasket?
Where can one find the replacement gasket?
The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide. I have not been able to find with basic search terms.
Thank you in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @kb_kb
If you can't find a replacement gasket, you may have to improvise.
Try either a suitably sized elastic rubber band or perhaps run a thin bead of neutral cure silicone sealant around the case in place of the gasket.
If using the sealant and you need to open the case in the future use either vinegar or Isopropyl Alcohol to soften it first and then pry open the case.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
KB_KB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 276
