Ga door naar hoofdinhoud
The HP Pavilion x360 14 (specifically the 14-dw1010wm) is a versatile 2-in-1 laptop with a 360ยบ-rotating 14-inch multitouch display, an 11th-gen Intel processor, and Intel Iris Xe Graphics. It comes with DDR4 RAM, an NVMe M.2 SSD, and 3-cell, 43 Wh Li-ion polymer battery.
Screen replacement for x360
Hey everyone hope you are having a good day, has anyone ever replaced a screen on a HP Pavilion x360 ? If you could please show me a video or link a replacement that would be more than great!!
Is dit een goede vraag?
Score 3
2 opmerkingen
Hi @brandontunnell,
Please confirm the full model number of your laptop as shown on the product info label on the bottom of the laptop?
door
hp pavilion x360 14dw1013tu
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @brandontunnell
Here's the maintenance and service guide taken from this support webpage for the x360 14dw1000 series laptops.
Go to p.51 to view the procedure to remove the display assembly. On p.53 the LCD panel is being removed.
Also on p.53 you'll find the HP part numbers for the LCD panels that can be used. Usually the part number is somewhere on the back of the panel if you wish to verify which one you have now. Search online for the part number only to find suppliers that suit you best.
p.s. If you post the product number of the laptop (also on the info label) I may be able to find the part number for the screen so that you can order it before having to disassemble the laptop to find out what it is.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Brandon Tunnell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 52
Altijd: 637
