Ga door naar hoofdinhoud
Reparatiehandleidingen en instructies voor de MacBook Pro 13" met 2e generatie Apple Silicon (M2-chip) en 13,3" Retina-display. Model A2338. Voor het eerst uitgebracht op 15 juli 2022 tijdens WWDC 2022 naast de MacBook Air M2.
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
Is dit een goede vraag?
1 Opmerking:
Sadly its out of warranty !!!!!!
door
Voeg een opmerking toe
2 Antwoorden
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
Was dit antwoord nuttig?
2 opmerkingen:
door
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
door
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
1 Opmerking:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
door
Voeg je antwoord toe
Andrew Usherwood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 1,010
