Battery Replacement Not Accepted
Hello. I just received a replacement battery from iFixit, and my laptop won’t boot into windows with it installed. Placed the old battery back in, and everything works just fine.
Does Dell lock their BIOS down if non-Dell parts are installed? And is there a trick to bypassing this?
Battery is the Dell 69KF2
Edit: The picture is the error I receive when plugged in
Is dit een goede vraag?
5 opmerkingen
With the new battery installed, does it make it to the BIOS or does it completely brick up?
door 907fixer Deel
It makes it to the BIOS, but it warns me that the battery isn’t a Dell certified battery.
door Logan Endicott Deel
So it comes up and has a warning that your battery isn't genuine and it won't let you past it?
door 907fixer Deel
Yes. That’s exactly it.
Yep, I believe dell has some chip that does a virtual handshake with the battery to make sure it's oem.
Edit: Sorry i can't be of much be of much help, dell is kinda funny like that and I actually just went through this same thing but I ordered from parts people to make sure it was oem.
door Korey Wedgeworth Deel
