Ga door naar hoofdinhoud
Single-function printer with integrated ink tanks for fast, cost-effective, reliable colour printing including two years' worth of ink
15 Vragen Bekijk alle
Why is there space on top?
Whenever Im printing, it leaves too much space on top of the paper and the remaining content gets cut off on the bottom of the paper.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Even though I don't own this printer, I do own a printer which used to do this before. Have you tried to "Calibrate" the print through your printer's settings? Is the page size set correctly in the settings? [If your printer is set to print on a different sheet instead of the current sheets you have, this could be it.] Are the settings set correctly to print? Are the pages set to print in "Portrait"? [Sometimes "Landscape" can cause printing to cut off]
Was dit antwoord nuttig?
Voeg je antwoord toe
Patrick Raven Javaluyas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 51
