Ga door naar hoofdinhoud
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
Display Trouble Shooting Steps?
Hi
I am trying to fix a broken screen on a SM-T510.
I have replaced the screen, and tablet is turning on ( as charge sound can be heard when cable is connected) but there is nothing displaying, and nothing visible when shining a light. I have reattached the old screen ( which had been showing display behind all the damage) and now that is not showing anything either.
I have ordered a new LCD flex cable just in case, but it may have been something else damaged while changing the screen as I only realised after I had not disconnected the battery fully.
Following the troubleshooting steps for display, it says to test C7020 for 27v, and if abnormal resolder or replace U7003.
I have a schematic diagram and can see C7020, but where is U7003 as I can't make out it anywhere when the quality is lost after I zoom in?
Also just in case, the next steps are
Check C7018 and C7019 for 5.6v, if abnormal replace or resolder U7001.
Check C7017 for 1.8V, if abnormal check the U7000.
Where are all these located also?
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@dav68123 here you go
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, that's perfect.
door
Voeg je antwoord toe
Dav zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 296
