Ga door naar hoofdinhoud
An Acer Aspire 5100 Laptop with a 15.4" inch display.
For some reason it is not charging whatsoever?
how would i find out whats wrong with it and acces where the charging port is
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Of course, make sure your AC adapter is working properly, and that you have a good battery. Make sure all your connections are clean and properly aligned. I f any of this is okay, you will have to dis-assemble your computer. Follow this guide. In the last picture, you will see the DC connector. Unsolder the old one, and replace it with one of these Here you can see what it looks like. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Leo Draper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,175
