Ga door naar hoofdinhoud
Replace the trackpad button
Does anybody know if, and how I can replace the trackpad button? I have two upper cases, one with a bad trackpad button, the other with a not functioning on / off switch. Try to make one good upper case.
Is dit een goede vraag?
2 opmerkingen
What is the macbook model ? Please update your question by adding the last three letters of your macbook serial number.
door
My Macbook 1s an A1181Core 2 Duo. Last four letters of the serial number are POPO
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It can't be done ;-(
The metal plate that seals everyting (keyboard, trackpad, buttons) is welded and glued in place. I have tried time and time again, it cannot be removed without damage. Industrial design the way it shouldn't be. Sigh. Get yourself a new topcase, they are not too expensive
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ I agree with remacberlin. No way to replace the trackpad without damaging the top case.
door
does the top case come with a fixed trackpad button
door
Voeg je antwoord toe
Fons zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,880
