Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Vraag afgerond
Replacing Cable #1 on 3GS Screen
I have several 3GS' in various states of repair. One has a functioning LCD and digitizer, but the connection on the #1 cable at the top of the screen doesn't hold. The connection on the board is ok (works with other screens) but not on the LCD.
I have a broken LCD with a good #1 cable. Is there any way to port the cable from that LCD to the good LCD? That would be cheaper than $100 for a new LCD.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Why do that when you can just remove the LCD from one and transfer it to the other? 6 screws to hold the LCD to the midframe, remove those and do the swap. Then crack open a beer to celebrate.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,138
