Ga door naar hoofdinhoud
The LG Velvet is a flagship slate Android smartphone released by LG in 2020. Identifiable by model numbers G900/910, followed by a version/carrier specific character set.
Vertical lines of colours on screen after a fall
I accidentally dropped my lg velvet fone on the ground and now there is different vertical lines of colours at the right side of the screen and three strips of lines on the left any help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@enochboateng without seeing it but going by your description and knowing this happened right after it got dropped, it sounds like a bad display. SInce iFixit does not yet have a guide for this, use some videos like this or even [https://www.youtube.com/watch?v=DMeC7YuV... |this one}. Replacement displays are readily available at many online stores. Pick a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Was dit antwoord nuttig?
Voeg je antwoord toe
Enoch Boateng zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 58
Altijd: 354
