Hi @renee56352
Does it start by itself when you disconnect the belt or do you still have to give it a push to get it started
Have you got the long vent model version or the non long vent model version?
If you have the non long vent version then perhaps check the wiring from the start button to the motor's M5 terminal
If you have the long vent model then there's a relay that is operated by the start button and it or its contacts could be faulty or it could also be a problem with the wiring to the motor's M5 terminal from the relay.
Here's an image of part of the motor circuit from the mini manual for the combo unit that may help.
By pushing the drum it may be enough to get the motor's centrifugal switch to operate and change the circuit path over so as to bypass the start button or the relay contacts (which should have been operated by the start button) and allow the motor to continue to operate on the run winding.
This would be made easier if the belt was removed, as there would be less initial torque required by the motor to start turning and the start winding may not be needed to help produce the required magnetism needed for the motor to start to rotate. It could start on the run winding only but for this to happen the centrifugal switch would need to be operated because perhaps there's a problem with the connection from the start button or the relay to the M5 terminal.
(click on image)
2 opmerkingen
Hi Renee,
Do you have a model number for your washer/dryer combo? That'll help the rest of us reference service guides and parts lists.
door Jerry Wheeler
Hi Jerry, model number is GUD27ESPM1DG.
door Renee
