Ga door naar hoofdinhoud
The third generation Kia Rio debuted on March 1, 2011, at the Geneva Motor Show, again based on the Hyundai Accent.
9 Vragen Bekijk alle
Hand Brake is stiff, gets stuck after 2/3 clicks
Hand Brake is stiff and if I pull it up too much, then it becomes a real pain to put back down. One time it got stuck and was pretty much impossible to lower, it finally gave after putting whole body weight on it. I think there is a problem with it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@yusufahmed possibly a rusted or stuck brake cable. Check the cable and see where it connects to the rear pads. It may not release from there. Check on here for a full description and the repair on the parking brake components.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks mate. Will check this out and see if it works ;)
door
Voeg je antwoord toe
Yusuf Ahmed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 153
