Ga door naar hoofdinhoud
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
Pendrive does not showing in drive
I have hp 16gb pendrive. When I put in my laptop, the pendrive is not showing in drive , when i tried to open it the computer give me msg " insert a disk" ,also tried to put it in tv but same it was not opened,
how can I open it ?
Is dit een goede vraag?
2 opmerkingen
@dharapatel45173 What operating system are you running (e.g. Windows 10)?
door
operating system is Windows 10
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @dharapatel1 , sounds like it could be a failed drive unfortunately! This is a pretty common failure mode when the NAND flash stops being able to be written to. The controller still shows up, but its no longer able to communicate with the NAND memory. It might be time for a new drive. Thanks!
Was dit antwoord nuttig?
Voeg je antwoord toe
Dhara Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 178
