Why is my camon 17 not booting
When ever I try to on it, it refuses to come on
Is dit een goede vraag?
@omowunmiemeana just because your phone says it has charged the battery 100% does not mean that it really is. The battery has a board on it that controls rate of charge etc and this may have failed. For that reason you want to try a new battery. Next part to replace after that is the charging board. Your CAMON uses a small charging board to distribute the USB power tec to the main board. You'd be looking for something like this Do not forget to check the flex cable that connects the charging board to the main board.
You can check the charging by connecting a voltmeter to the battery connector. Once you plug your charger in, the voltage on that will have to go up (around 4.2V) that way you know you are getting power to the battery connector from the charging board.
iFixit does not yet have guides for this phone but check videos like this one to assist you further.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 107
1 Opmerking
Hi @omowunmiemeana,
Does the phone indicate that the battery is charging when the charger is connected to the phone?
Has the phone been dropped or gotten wet at all?
door jayeff
