Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
1,6 of 1,8 GHz dual-core processor, 2 GB of 4 GB SDRAM, 64 GB of 128 GB SSD
Internal Storage not Detecting Full Capacity
The title sums up the issue. I dragged my old Macbook out of storage, tried to boot it up and it didn't detect an OS. I figured it would be an easy fix, booted it into recovery mode, and went to reinstall OS-X. The installer did not detect a drive that it could install to so I went into Disk Utility from recovery mode and disk0 with Mac OS X Base System is listed, with only 1.19 GB total storage. Clicking "Erase" does not let me do anything, nor do "First Aid" or "Restore". Mostly wondering if I can fix this somehow or if the drive is probably dead.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Replacement drives for this model have dropped in prices. I'd drop a new one in, here's how to do it:
MacBook Air 11" Mid 2011 Solid-State Drive vervangen
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Are there any other possible solutions? I don't really want to spend the money on a drive if I can avoid it, as I don't really care about the laptop to begin with.
door Deel
If it were in my shop, I would hook it up first to an external drive with an appropriate operating system installed using a USB adapter and see if it boots. But I don't know what you have available.
door Deel
The laptop does boot Linux Mint and Arch Linux, but I can't install them since they don't recognize a storage device to install to.
door Deel
Your facing a file system mis-match! The recovery is based on the older HFS+ where as the drive has been upgraded to High Sierra or newer which then converts to APFS.
You’ll need to create a bootable OS installer which is running a newer macOS to then run Disk Utility and you may need to re-install the OS as well.
Score 1
Voeg je antwoord toe
tmbh21 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 438
