phone not charging not showing proper charge
I dropped my phone and now it's not charging with same adapter or other charging not charging sawing all time
Is dit een goede vraag?
@prinkalben87671 sounds like a bad/disconnected battery, torn flex cable from the charging board or a broken charging board. Use this guide to open it up and to check your battery Xiaomi Mi 11 Lite Battery Replacement Once the battery is removed, you can see the flex cables from the charging board to the main board. Check those for tears and if they are disconnected. If so, replace or reconnect. To replace the charging board, use something like this video
The charging board is readily available and many online places. Select a vendor that appeals to you.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 199
