Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Vivo V5 is een smartphone van Vivo. De telefoon werd uitgebracht in 2016.
Display Screen is Broken.
The screen is broken and the batter is also finishing up too fast . What could be the solution for this ? .
Is dit een goede vraag?
Score 13
16 opmerkingen
Vivo 1609 Phone display broken solution
door Deel
Display of Vivo v5 is damaged
door Deel
See my previous answer for how to replace the screen yourself.
door Deel
Battery not working properly
door Deel
My display is broken what can I do
door Deel
11 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Yash wanth, you will need to replace the screen, and as long as you're at it, a new battery replaced at the same time will give your phone a new life. I didn't find any iFixit-style step by step instruction guides for your phone, but there are a couple of videos made by the same author that show separately how to replace the battery and the screen.
I would suggest following the battery replacement guide first until the battery is free, then pick up on the screen replacement video and follow through removing the screen. Once the screen is back on, go up to the point where you would reconnect the battery then switch back to the battery video to finish up.
Vivo V5 Battery Replacement
Vivo V5 /5s LCD-Touch Replacement
Although the video shows the technician using a hot air gun to heat the screen adhesive for removal, in actuality a normal hair dryer will work fine; just let it heat longer obviously since it doesn't get as hot.
Other than that, search places like Amazon, eBay and AliExpress for the parts you'll need to do the job; I saw screens available on Amazon and eBay for under $25 USD so they're readily available and the phone is old enough that the parts are inexpensive now.
Good luck; let us know how it goes! Take lots of pictures as you do your repair and use those to author your own iFixit guide to screen and battery replacement! It's fun, easy and the community will appreciate you!
Was dit antwoord nuttig?
Score 2
1 Opmerking:
What’s a price of battery and display.
door Deel
Mere phone ki display kharab ho gai kaise theek kar sakta hun
Voeg je antwoord toe
Yash wanth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 91
Altijd: 3,420
