Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
Auto Restarting every 3 minutes
Hello Guys, The device was physically damaged and had a original display replacement. But the device has still the same 3 minute reboot. Tried all the software troubleshooting and also tried removing all the flex except battery and display to find the sensor but couldn't resolve the issue.
This is the panic log.  Any ideas?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@oldturkey03 is exactly right, the PRS0 sensor is a pressure sensor that works with the barometric vent and is located on the charging port assembly flex cable. So yeah, in addition to the new screen you're going to need that lightning port assembly replaced as well.
If you're interested in learning more about those kernel panics that are rebooting the phone, Alisha ( @flannelist ) has written an excellent wiki article on the subject; it point you directly to the charging port after finding that missing sensor: PRS0 line.
iPhone Kernel Panics - iFixit
Sorry to say, iFixit hasn't gotten around to creating a lightning port replacement guide for your phone yet, but I did find a good one on a Spanish side called Nadie Me Llama Gallina, or Nobody Calls Me Chicken. Use it with the Chrome web browser's automatic translation and you won't have any trouble; just note that "battery" gets translated as "drums" and "flex cable" come across as "tablecloth"; other than that it's straight forward and easy to follow.
Manuales / Apple iPhone Xs Max / Flex with load connector and lower microphone - Nadie Me Llama Gallina
The parts themselves you can get anywhere; I usually start with Amazon, eBay and AliExpress depending on how cheap I am vs. how fast I want it. Of course, you can support iFixit's repair efforts by purchasing the part right here; don't forget to pick up a sheet or two of the precut adhesive for sealing the screen back up when you're done.
iPhone XS Max Lightning Connector Assembly
Replace a lightning connector assembly compatible with the iPhone XS Max. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-01415. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
24.A Monish.M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 472
