How do I disconnect my fuse box under the hood
How do I disconnect my fuse box under the hoid
Is dit een goede vraag?
@stephensvrcek use the workshop manual to remove the Lamp:
HEADLAMP UNIT
REMOVAL
LAMP
1. Disconnect and isolate the battery negative cable.
2. Remove the grille panel from the grille opening reinforcement.
3. Remove the two screws that secure the mounting tabs (3) on the inboard side of the headlamp unit housing (2) to the grille opening reinforcement (4).
4. Pull the inboard side of the headlamp unit away from the grille opening reinforcement far enough to disengage the locator tab (5) on the outboard side of the unit from the engagement slot in the outboard edge of the reinforcement.
5. Pull the headlamp unit away from the grille opening reinforcement far enough to disconnect the wire harness connectors from the headlamp bulb socket (North America), the headlamp bulb base (Export), the front position lamp socket (if equipped), and the headlamp leveling motor (if equipped).
6. Remove the headlamp from the grille opening reinforcement
Here is the part from the manual Jeep Liberty Lamps
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 77
2 opmerkingen
@stephensvrcek just wondering why you would want to do that. Are you planning on removing the complete fuse box?
door oldturkey03
No I need room to replace my headlight
door Stephen Svrcek
