Green lines on my display
Green lines all over my display
Is dit een goede vraag?
@itsabssam you are not telling us if they did just all of a sudden appeared or if something happened to your phone. The most common issue would be a broken display. I would start with replacing it. Use something like this video for the repair. New displays are readily available. Just do an online search and select a vendor of your choice.
If a new screen should not fix this, you will need to check the LCD connector on the board as well as the board itself for missing components etc.
Was dit antwoord nuttig?
I have Green line what I do now
Hi Omar,
Green lines on a screen are almost always a result of a bonding failure between the glass that the circuitry is printed on and the flex cable attaching it to the motherboard. That sort of damage isn't repairable, so replacing the screen is really all you can do. See @oldturkey03's answer for information on a video showing you how to do that replacement, assuming your phone is the same as that for the original poster.
First tell me lines are vertical or horizontal otherwise please change the folder
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 117
Altijd: 890
7 opmerkingen
My phone screen
showing green lining
door suraj sharma
Please read @oldturkey03's answer above and include more information about when the problem appeared and anything that might have caused it such as being dropped, exposed to liquids, etc.
And, of course, if your phone isn't a Vivo 1907 you'll need to tell us what kind of phone you do have.
door Jerry Wheeler
Screen get blue so that what can do
door Fffg Rfj
@fffgrfj read the comment by Jerry Wheeler just above your question. Do what is asked in there so we can at least try to help you somewhat.
door oldturkey03
Vivo y20a diple wait ho jata hai
door Hifazat khan
2 commentaren meer tonen
