Ga door naar hoofdinhoud
12,1-megapixel compactcamera uitgebracht door Sony in 2009.
says reinsert memory card and then memory card error even with a new c
says reinsert memory card an then memory card error. even with a brand new card
Is dit een goede vraag?
1 Opmerking:
@ccoe what make and size card are you using?
door
Voeg een opmerking toe
1 Antwoord
It can possibly be three different factors:
  1. Your SD card is formatted in a format that differs from the one that your camera is able to use. In this case you'll only need to format it to FAT32 on your PC (you can find plenty tutorial on this website or on YouTube).
  2. Your SD card has an architecture impossible to read by your camera. Check that your camera supports the type of SD you're using (may it be SDHC, SDXC or others)
  3. Your SD card became corrupt and the camera isn't able to read or write to it because of this. If this is the case you'll need to buy a brand new SD card;
If it's not one of these then it means that either your camera has a faulty memory reading unit or, worse, your camera has a faulty CPU, which means that you'll have to change camera...
Was dit antwoord nuttig?
Voeg je antwoord toe
C Coe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 448
