Ga door naar hoofdinhoud
Een spelcomputer voor in de hand, gemaakt door Valve en uitgebracht op 25 februari 2022.
Where can I find parts not on iFixit?
I was doing a full case swap and accidentally broke part MEOJ24900KDL. It's the long ribbon cable that goes along the top vent. I've tried looking in few places but can't seem to track anywhere down to get a replacement. I also suspect I broke the ribbon cable from the display to the motherboard, but I might just buy the upgrade screen anyways, will see. Anyways, whatever help would be much appreciated!
Is dit een goede vraag?
Score 4
16 opmerkingen
please check that part number
door
@mayer I did check it again and got the same number of the barcode. However I was using Google lens which might be the problem. Im going to try a different barcode reader but for now I just uploaded the pictures if the part and barcode.
Edit:
I tried 2 more qr readers and got the same part number off of both.
door
@drevis25 what else does it say on the ribbon cable? To the left of the FPC....
door
@oldturkey03 Three things, 2248 TSF (in small print) F7A_MIC_FPC, in that order.
door
@drevis25 looks like the Mic Flex. Now just to find it......
door
11 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hey guys I wanted to let you know I bought my replacement from for this eBay seller:
https://www.ebay.com/itm/115989144859?mk...
Mine hasn't arrived yet but I"LL keep you updated once is been installed
(REED DESCRIPTION TO WHICH DEVICES ARE COMPATIBLE WITH !)
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Looks legit!!! You are my hero!!! I'll wait for an update before by but again it looks promising.
door
As soon I get it installed and tested I'll let you know 😉👍
door
Update: Mic Flex (F7A) arrived in great shape and good packaging.
I have made the installation and it worked flawless, I also upgraded the LCD to a 1200P from DeckHD and changed the shell for a clear version from Jsaux.
door
@drevis25 given its a new device, I'd contact Steam and see if they'll let you purchase new parts directly. It may be a while before used parts start showing up on eBay, that usually only happens once warranties start running out.
kasynparts have this parts
Voeg je antwoord toe
Drevis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 81
Altijd: 1,890
