Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Onkyo TX-800 is een solid state-receiver die in 1989 op de markt kwam en in 2002 niet meer werd geproduceerd.
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
Is dit een goede vraag?
Score -1
3 opmerkingen
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
door
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
door
Laura, thank you for accepting my answer. Best of luck to you....:)
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Laura zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 4,088
