Ga door naar hoofdinhoud
The Acer Timeline 4810T is a laptop designed by Acer.
7 Vragen Bekijk alle
no sound in internal speakers
Hi there,I Have a 4810t acer loptop i have no sound in my internal speakers but still i can use headphones by the way a red light coming frome audio sockt.
thanks for help
Is dit een goede vraag?
Score 1
8 opmerkingen
Hi every one I have a 4810t acer loptop ,my problem is abought audio device that is no sound frome my internal speaker but still i can use headphones and a red light coming frome audio socket.sorry for my bad english writing i am persian.
door
Arash, your English is fine. Welcome to iFixit...:-) anyhow, are you running windows on your computer? Have you checked in the settings to make sure that your speakers are on?
door
thanks..my windows is 7 and i recoverd my system and checked all setings but that wasn't helpful.pleas any better idea.
door
Arash. what happens when Right-click the speaker icon on your taskbar > Select 'Playback Devices'
In the empty space, Right-click and select both 'Show Disconnected/Disabled Devices' Do you see icons for your speakers now? If you do, you can right-click and enable them, as well as set them as default.
Arashm what do you see in your device manager under the
door
hello again and thanks for answers but i have to say one mor time that my driver isn"t missing and its up to date and i can hear sound from headphons.just speakers have no sound and by the way i even opend the loptop and checked speakers and thay were unscathed,but still i can"t hear sound from speaker Directly.
door
3 commentaren meer tonen
Voeg een opmerking toe
8 Antwoorden
Het nuttigste antwoord
I have the very same problem. Already checked drivers, windows configurations, even opened the laptop and checked whether speakers powered on or off. May be it's massive manufactural problem? Has anybody solved such problem?
Was dit antwoord nuttig?
Score 1
Hi, did you solve the problem with the internal speakers? It's about two years I've the same problem with the same pc and haven't found any solution. Thanks for sharing what you discovered in case.
Score 1
Go to the control panel and select the sound icon. If it says the speakers are not working right click on speakers and either select enable or configure.
1 Opmerking:
You can try opening the volume control and make sure the speakers are not muted. If that does not work you may want to make sure the sound driver is not corrupted or up to date. You can download slim drivers at WWW.driverupdate.net. It is a great program for fixing missing, corrupted, or out of date drivers and it is free.
door
It's not my right speaker and the headset works. I guess it is a physical problem. if someone has an idea or to open it
thank`s
me, i have the same Problem - and seen that it is a broken contact from the Headset connector
so how to change the connector?
Greatings from Germany Uli
Me too, have taken much time to make sure I don't have a software or hardware problem, (Acer 7741Z-4433 Windows 7 64bit) those avenues are exhausted and I also still have no sound: a couple weeks ago I noticed an exceptional amount of dis-engaged noises while the speakers were still working so know it is a mechanical problem.
I am looking for an external speaker or headphone to try the external connection. I suspect that will be affected as well. So, am saving all my videos and music recordings to another ex drive so I don't lose them when the rest of the systems fail!! Not optimistic in finding a solution.
Thank you soo much, problem solved.
1 Opmerking:
can you tell me how to fix it? please send on my email muhaziziqbal06@gmail.com
Sorry bad english.
door
Put your finger near in the front of headphone socket (about 1/2cm), are you see the red light ? if no, its may occur by driver. try reinstalling the driver or updating the driver ... if yes. it happen because headphone socket(jack) support SPDIF (digital out) its a mechanical problems (my 4810t had the same problems) i just push the spdif sensor in headphone socket with a needle. sometimes its working. sometimes i jush punch the socket :LOL. better take your laptop to acer service center.
Voeg je antwoord toe
Arash zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 7,718
