Why aren’t my fans spinning up?
I recently took apart my old 2008 Xbox to clean it. It works as intended, but soon overheats because fans won’t spin up. I replaced the fans thinking they were damaged but the same issues came up again. I honestly don’t know if they were working or not before I opened it up to clean it. So I’m thinking it’s a fan controller issue or some damage on the motherboard. Any help or guidance would be greatly appreciated.
Update (07/15/23)
@oldturkey03 I think it’s a 2008 model, it’s black and uses the 203 watt power supply.
Is dit een goede vraag?
3 opmerkingen
@cav02 do you know what model your 360is? Do you still have it apart? Post some good pictures of your boards with your question. That might help us to identify what you have going on there.
door oldturkey03
@cav02 have you checked for power on the fan connector. It should start out at 5.4VDC then go to 11.8VDC. If you do not have that voltage, it is possible that the issue is the SMC fan control which drives the 2 PWM for the fans.
door oldturkey03
@oldturkey03 do just use a multimeter to check the voltage of the fan header? Also what does the fan controller component look like on the motherboard?
door Cav02
