Ga door naar hoofdinhoud
The HP ProBook 450 G2 is a 15.6-inch business laptop marketed toward private and business users.
10 Vragen Bekijk alle
My Laptop is not switching on
My laptop is not switching on
It has a Blank screen with the power glow on the charging port on, but without the glow of the Power button Caps lock (no blinking sequence) when connected to a/c
I have tried to Remove the power source and press the power button for 20 seconds with no success
regards
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @brianmayega
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
I realize that you said that you did “… Remove power source and press power button for 20 seconds.....” but sometimes it is necessary to remove the RTC battery (Real Time Clock) from the motherboard as well to reset the BIOS back to its default state.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Remove the RTC battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.83 to view the necessary pre-requisite steps and then the procedure to remove the RTC battery. Unfortunately with your model you will have to remove the motherboard to access the battery.
When the battery is removed measure its voltage. If it is <2.6V DC replace it. The part number is 738824-001. Search online using the part number only, to find suppliers that suit you best.
d.) Reconnect the RTC battery (or its replacement).
e). Reverse the above steps to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Brian Mayega zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 177
