Why my car has problem with the injection
It say check injection and some time slow down from 100 to 60
Is dit een goede vraag?
Sounds like either your injector pumps are starting to go bad or it could be reading bad injector codes because your breather filter needs to be changed.
Was dit antwoord nuttig?
I had the same problem, and checked it with ODB which said to "change the petrol heating sensor"
# I fuel it with High Efficiency petrol 2 times, and got better.
# Then I fuel it with 85% petrol and 15% benzine ( hoping to "clean" the injectors) and got better results.
Anyway it's an old car, but I think is better to check and if it need, change the injectors.
Sa peut être le mano HP ou les injecteurs qui ne va pas il faut un scanner pour être sûr
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 82
Altijd: 1,210
@hliasmoust12265 if you scan your OBD II, what exact error code do you get? "Check Injection" is just way too broad to do anything with it.
door oldturkey03
I gave it to mechanic he pluged it and he didn't show anything...this happen when im in a hill after that its normal
door hlias-moustafa giounes
@hliasmoust12265 so this only happens when you go uphill? does that mean anytime your Renault has to work hard, you get a "Check Injection" error?
door oldturkey03
