Ga door naar hoofdinhoud
The Dell Inspiron 15 3558, part of the 3000 series, is a 15.6 inch desktop-replacement laptop with solid specs, plenty of storage, and long battery life.
Can’t find my Wi-Fi network, but sees others?
I went to use my laptop today but I noticed it shows all my neighbors Wi-Fi but not mine. It was working fine earlier today but now it doesn’t show it. When I boot into Linux it sees it but not Windows. My Wi-Fi is Eero Router.
How can I fix this without reinstalling Windows?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@stechkid
I believed is the Wifi 6 ax mode in your router causing older drivers not to show up, which I had experienced it before.
is your wifi model intel 7265?
https://www.thm.de/its/images/stories/An...
Some possible fix,
1. update router firmware to latest
3. Download latest wifi drivers from Dell website and install.
https://dl.dell.com/FOLDER05736979M/4/In...
3. alternative drop the wifi mode on your router to wifi 5 mode
Was dit antwoord nuttig?
Score 1
if it was working fine earlier today, then unless something updated or tried, it is a hardware problem. I have a router that doesn't transmit on one of the configurations. Fortunately, it has 3 Guest configurations and I switched it to another.
2 opmerkingen:
When booted into Linux it sees it fine and it can see my other networks so my laptop’s fine
door
Hi @stechkid
Try just uninstalling the Wi-Fi driver in the Device Manger (devmgmt.msc) and let Windows reinstall it. This often fixes little problems.
door
Voeg je antwoord toe
80stechkid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 160
