notebook E406n wont turn on power led lit charging led blinks white 3
mi notebook asus e406n shut down and wont turn on again pressin power button lits white led and charger led goes fron orange to blinking 3 times white and nothing more, i open and unplug the battery all ready discharged the "static" process, unplug all periferials and just plug in charger and push power and the same just led and blinking led white. any solution? ps: i lefted for over 3 days unppluged from the battery and came on again i reset it to factory settings so if it was a software issue and worked fine during the hole process, after i lef it downloading and installing windows updates, for a while screen whent to sleep mode and from there again it wouldnt turn back on.
Is dit een goede vraag?
@pcinknet Commonly Asus computer do the 3 blinks when the HDD or SSD depends on what you are having, can't be found. This "after i lef it downloading and installing windows updates, for a while screen whent to sleep mode and from there again it wouldnt turn back on" does not seem to be consistent with that. As for right now, if your computer does not come on at all, disconnect your HDD and see if that changes anything. See if you get any kind of message. Do the same with your RAM. Just in case, connect an external monitor as well and see if that shows anything. I wonder if this is in relation to your Windows update.
door oldturkey03
hi tnks for your input but... first if you look into the model you will see that all is integrated on the mainboard ssd and rams, so no way to "extract them" and no message what so ever screen doesnt shows image its completly off, and dont think is related cause before that several updates were install and ask to restart and it did it without problems. i even replace the motherboard and does the same with the replacement...
door PCInk Net
@pcinknet so this is a new motherboard and no change?
door oldturkey03
no power on as the old one... wierd case!!!!
door PCInk Net
