Ga door naar hoofdinhoud
Uitgebracht in juni 2017 als opvolger van de Surface Pro 4. Ook bekend als Microsoft Surface Pro 12,3". Modelnummer: FJT-00001.
Replaced Battery, this is what I got..
Was wondering what I broke here? I was very careful and it seemed to be okay when I replaced the battery and reassembled it.
The screen is not cracked, but I was wondering if it was a connection issue. However, why would just a strip display like this?
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I am sorry to say this James, and others can chime in here if they disagree, but I'm pretty sure that screen is dead.
There's a chance it is a connection issue. Did you try reseating the cables? But if not, it is likely a separation issue where the screen was pulled apart and the layers through which the data connection flows were separated at some point.
It is not exactly your fault, Microsoft has made these things as hard to service as possible (they earned the lowest possible repairability score for a reason), and no matter how careful you are screen issues have been known to happen on Surface devices.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
James Buchanan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 278
