Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De DVP-SR200P is een Sony dvd-speler die dvd's of cd's kan afspelen en vier knoppen op de voorzijde van het apparaat heeft. Het wordt niet langer door Sony geproduceerd.
Power On/Off not working
Afbeelding
Afbeelding
Afbeelding
Actually, my device wasn't listed....***.
I want to fix a Sony 5 disk, CD/DVD player for 95 yr parents who don't have the Internet to watch movies or stream music (can't afford it).
They have a Sony player, model DVP-NC665P, Serial #1103500.
For a while it has been turning on, sometimes not. Pressing the button sometimes caused an instantaneous blip of display, top middle of the screen, and then it goes out. Now nothing happens.
Any idea of what to fix or replace? (Thanks for the idea to include image(s) of circuit board(s). Hope that helps.
Thanks,
John
Is dit een goede vraag?
1 Opmerking
@john16096 Can you take the top off the player and upload pictures of the circuit boards inside? Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
This isn't the answer but a beginning to an answer. Service Manual for Sony DVP-NC665 DVD Player:
Service Manual
I presume it doesn't work with either the remote nor the power button on the actual unit?
Do you have any experience with electronic repair and reading schematics ? Do you have a multi-meter?
If no, either get an experienced friend to help or at the very least make sure the unit is unplugged and remember that the capacitors (the small drum shaped components) can still hold a charge and give you a shock.
A good place to start would be page 83 or 6-1 which explains how to start the Test Mode - press in this order [TOP MENU], [CLEAR], [POWER] keys on the remote and lists the Power Off Information Code List and what they mean. Does the Test Mode Menu even appear on the TV monitor?
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
NOTE: Interestingly, The manual site lists it as NC665, but clicking on it, it goes to NC625. Maybe it's close enough to work for both. Thanks.
door
@john16096
The manual covers both model numbers plus some more - depends on where they're marketed
door
Mine was doing the exact same thing and I found that pressing the following buttons all at the same time caused the machine to power back up after a brief initialization. Press on the remote all three of these buttons at the same time.
TOP MENU
CLEAR
POWER BUTTON
My machine immediately Returned to life.
Score 2
1 Opmerking:
billr625 - it worked! thank you!
door
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 40
Altijd: 1,148
