Ga door naar hoofdinhoud
De Milwaukee 2656-20 draadloze ¼” hex slagschroevendraaier is een op 18 volt batterijen werkende slagschroevendraaier die in januari 2014 werd uitgebracht. De schroevendraaier beschikt over 2 standen, vooruit en achteruit, en levert 1.500 in-lbs aan torque bij 2750 TPM.
Impact driver will not turn on
When the trigger is pressed nothing happens and battery is good.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Give the troubleshooting section a try and let us know what you find.
Milwaukee Hex Impact Driver 2656-20 Troubleshooting - iFixit
You may need to open it up if you're handy with a volt/ohm meter so you can test the operation of the trigger. This guide will get you access to it for testing.
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement - iFixit Repair Guide
Tell us the results of your troubleshooting and we'll see where to go from there.
Was dit antwoord nuttig?
Si funciona abeses puede tener arena
Spanish->English translation:
If it works sometimes, it might have sand in it.
1 Opmerking:
The first thing to do is open it up and clean it out; sand will destroy the gears and brushes in a short amount of time. This guide will show you how to separate the case so you can access the internals. Blow it out with compressed air and use a brush to clean out any particles that are stuck.
Demontage van de behuizing van de Milwaukee Hex Impact Driver 2656-20
If it still works intermittently after that, come back and let us know what you found when you opened it up and if it still has the same problem or if anything has changed.
Lo primero que debes hacer es abrirlo y limpiarlo; la arena destruirá los engranajes y las escobillas en poco tiempo. Esta guía te mostrará cómo separar la carcasa para que puedas acceder a los componentes internos. Sopla el interior con aire comprimido y utiliza un cepillo para eliminar cualquier partícula que haya quedado adherida.
Si, después de esto, sigue funcionando de forma intermitente, regresa y cuéntanos qué encontraste al abrirlo, y si el problema persiste o si ha cambiado algo.
door
Voeg je antwoord toe
Jose Sanchez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 414
