Ga door naar hoofdinhoud
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
Wat je nodig hebt
    1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: stap 1, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: stap 1, afbeelding 2 van 2
      • Squeeze the red buttons on the battery.
      • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: stap 2, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: stap 2, afbeelding 2 van 2
      • Lay the impact driver on its side.
      • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
      • Separate the two halves by pulling up on the top half.
      • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
      • Lay the top half to the side.
      Vraag FixBot
      Voeg opmerking toe
    1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: stap 3, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: stap 3, afbeelding 2 van 2
      • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
      • Move the two wires out of the way.
      Vraag FixBot
      Voeg opmerking toe
    2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: stap 4, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: stap 4, afbeelding 2 van 2
      • Gently pull up on the trigger assembly to remove it from the case.
      Vraag FixBot
      Voeg opmerking toe
    3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: stap 5, afbeelding 1 van 1
      • Remove the trigger assembly from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 1,783
