Xiaomi replacement battery not working
My phone battery is addicted and I bought a new one and replaced it but I can't get my phone to work.
I bought an original BN52 battery that is compatible with this device.
The only thing that I see is the notification led blinking when I connect the new battery.
I already try to disconnect the battery, plug the charger, connect again and the behaviour is the same.
I already try 2 new batteries without sucess.
Any sugestions?
Is dit een goede vraag?
@zalho so what happens when you install the new battery. Does your phone come on at all? what have you checked?
door oldturkey03
@oldturkey03 when I connect the new battery the only thing that happens is the notification led that blinks, the phone won't turn on. I already tried with 2 new batteries.
If I connect the old battery (that is addicted) the phone turns on normally.
door Zalho
@zalho is that the same for the second new battery. Since the old battery works, you know its a battery issue. I would try one more battery but get it from a totally different vendor
door oldturkey03
@oldturkey03 exactly, I tested 2 new batteries in the last days and with the same behaviour. One month ago I've tested other functional battery from other vendor and with the same problem. All the batteries are originals from Xiaomi. The only difference is the battery model, the one that came in phone is BN53 and all the other 3 tested are BN52, but they should be exactly the same, all them should be compatible.
door Zalho
Charge the batteries. That also happened with my phone but with it's normal battery and after charging it I noticed that the battery had almost no battery
door Juanma
1 commentaar meer tonen
