Drone tilt's upon takeoff
Drone tilt's to one side upon takeoff
Is dit een goede vraag?
Have you checked that all the propellers are situated in their correct position and are orientated correctly i.e. not upside down?
usually propellers are marked as to where they should be place on the drone and also what side is facing up.
Most user manuals for drones show how to connect the propellers to the body of the drone
Was dit antwoord nuttig?
Check nothing is interfering with the motors on the side that lifts last. One motor isn't spinning up as fast as the others causing the drop in one side. It's possible you may need to fit a new motor. Try a drop of fine oil on the shaft at the bearings incase they are a bit dry.
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 51
2 opmerkingen
@angelocenotti got a make and model for this Drone?
door oldturkey03
it is a protocol galileo stealth w/camera
door Angelo Cenotti
