Ga door naar hoofdinhoud
Repair and disassembly information for the ProBook 440 G7 laptop. This 14 inch business laptop was made in 2020.
Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Is dit een goede vraag?
Score 1
4 opmerkingen:
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
door
No it's actually beeping like a car's blinker
door
Could you possibly record it and add it to the post?
Not sure how?:
Voeg afbeeldingen toe aan een bestaande vraag
door
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
door
Voeg een opmerking toe
1 Antwoord
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Was dit antwoord nuttig?
1 Opmerking:
None of them helped
door
Voeg je antwoord toe
Jackson King zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 207
