Ga door naar hoofdinhoud
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
20 Vragen Bekijk alle
Can I fix this pulsing rumble?
I bought a new V2 controller and as soon as I turned it on, it started a rumble coming from the right motor. It was like the controller had a pulse. Hopefully the fix isn't difficult.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It could be glitchy firmware. Try resetting it, paper clip in the hole on the back for 10 seconds, then resync it. See if that works. The fix could be easy, or not. But the time and potentially complicated troubleshooting it down to the culprit might not be "easy". If you bought it brand new, I'd return it as defective and get a replacement. There are so many things it "could be". From the processor to the wires/ribbons, to the motor itself. This is a new one for me, haven't come across this particular problem.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Luis Gonell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 56
