Ga door naar hoofdinhoud
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 Vragen Bekijk alle
Computer crashes to a blank green screen.
I’ve recently built my first pc and for the 1st day it was running great. Yesterday and today hasn’t been the same. After only a few minutes of running the pc will crash in to a blank green screen. Any tips? Anyone else ever have this problem?
Is dit een goede vraag?
1 Opmerking:
Hi @koithyboi,
What is the make and model number of the motherboard and the GPU card?
Try disconnecting the SSD (HDD?) and check if you can get into BIOS OK with a display.
Have you checked the monitor's working OK i.e. can you view the OSD menus?
door
Voeg een opmerking toe
1 Antwoord
What operating system is it running on?
Was dit antwoord nuttig?
2 opmerkingen:
Was running windows 10 when it started. Upgraded to windows 11 only for it to crash more often
door
It could be a bios issue or corrupted files, maybe you should upgrade your drivers, it could be a monitor issue too
door
Voeg je antwoord toe
koithyboi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 64
