Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een draadloze Marathon-muis van Logitech die in 2010 werd uitgebracht.
Fix Left click button
Left click don't work while all other buttons work properly
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Imad, when you press the left click button, does it still make a sound? If not, you probably either need to replace the switch (the mechanism that registers clicks) or buy a new mouse (if you don't want to disassemble your mouse), and if so, it's probably something a bit more complex, in which case I would heavily recommend buying a new mouse.
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Dear Shingle
Thank you for your quick reply.
Yes i still have a click sound ;what to do in this case?
door Deel
@imadchidiac Well, that means that the switch isn't broken. What specifically are you using the mouse for? Also, how long have you been using it for?
door Deel
I used for a smart TV less than a year
door Deel
Hmm. And all the other mouse buttons work? That's quite strange. Have you tried using a different mouse? If left-clicking doesn't work with the different mouse, then it is a problem with your smart TV. If left-clicking does work with a different mouse, then you should probably just buy a new mouse. Personally, I would recommend the Logitech K400 Plus if you want a trackpad-keyboard combo, or either the Logitech M705 or M330 if you already have a keyboard (the M705 has better battery life, but is slightly more expesnsive, and both mice are on sale).
door Deel
I have this issue and am willing to explore other options. The device is out of warranty, so I have nothing to lose. If it still makes a click sound, what are some things to investigate other than replacing the switch?
door Deel
Maybe worth a try--what do you have to lose?
(I'd use electronic cleaner or 91/99% alcohol instead of WD40):
https://www.youtube.com/watch?v=-w-W6MAn...
Good luck!
Voeg je antwoord toe
Imad Chidiac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 2,895
