Ga door naar hoofdinhoud
Vertical lines on plasma tv screen
A few days ago a black line appeared that cut off the left part of my screen, today when I turned it on it was flickering between the Image and the black bar. After about 5 minutes a heard a click and then this colored bi-frost looking glitch appeared. What could it be? A few days ago a black line appeared that cut off the left part of my screen, today when I turned it on it was flickering between the Image and the black bar. After about 5 minutes a heard a click and then this colored bi-frost looking glitch appeared. What could it be? A few days ago a black line appeared that cut off the left part of my screen, today when I turned it on it was flickering between the Image and the black bar. After about 5 minutes a heard a click and then this colored bi-frost looking glitch appeared. What could it be? A few days ago a black line appeared that cut off the left part of my screen, today when I turned it on it was flickering between the Image and the black bar. After about 5 minutes a heard a click and then this colored bi-frost looking glitch appeared. What could it be?
Is dit een goede vraag?
Score 1
1 Opmerking
After opening I found what looks like a burnt chip on a ribbon cable
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@memeking628 that is called a COF and yes it is "toast" sometimes those ribbon can be replaced other time this spells the end of the TV. Do a search on YT for the COF repair and see what is involved with this. this will cause the issues you are describing.
Looks like our spam bot mistook your prior question as spam and deleted it. It has been restored.
Yes, this part can be the cause on that question as well.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Meme_king628 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 365
