Extremely low volume on all settings
When I start the CD player or radio the volume ist almost inaudibly low. It doesn't increase with setting for volume.
It's a Sony CFD-S05 model casette, cd and radio.
Is dit een goede vraag?
So I found the solution. In my case the capacitor C303 by the side of IC301 on the mainboard was getting super hot and the chip didn't get the voltages it needs. After replacing it with another capacitor of the same voltage rating and capacity (100µ,10V (105°C)) but with higher temperature rating, the device works perfectly again.
If anybody has the same problem, this Sony CFD S05 SM document helped me to understand which chip is involved in determining the volume and where to look.
Was dit antwoord nuttig?
Hi, I had the very same problem but with the CFD-S07CP model and this solution fix the volume issue. Thank you so much for the info.
Thank You very much! Replace capacitor C303 saved my device too.
Mein Problem mit Sony CFD-S05: die Lautstärke ist etwas reduziert und der Ton ist verzerrt. Hat jemand einen Tip?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 932
