Ga door naar hoofdinhoud
Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
20 Vragen Bekijk alle
battery contact cable adhesive
I am rebuilding, having replaced the battery. In one of the later steps you heat the adhesive on the battery contact cable before gently removing. in the reverse - what adhesive should i use to fix the cable? it looks like its fixing to an aluminium patch - should i use thermal compound or regular hot glue or double sided tape?
thanks in advance
Is dit een goede vraag?
2 opmerkingen:
do you mean the flex cable from the battery with the gold contacts ?
door
yes that is it... It looks like it had a copper like adhesive or possibly tape of some kind.
door
Voeg een opmerking toe
1 Antwoord
Nothing fancy required. just used double sided tape. I did leave the copper P- pad in contact with the chassis. all appears to be working fine.
Big thanks to daniel (above) for help with this
Was dit antwoord nuttig?
Voeg je antwoord toe
SteveG zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 76
