Ga door naar hoofdinhoud
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
Unresponsive screen touch won’t work
Touch screen won’t work to the touch rebooted it and also didn’t work, how can I fix it if I open it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You can check the flex cables to see if they're seated properly or damaged. If those are ok then you'll need to source a replacement screen. Just be sure to transfer the original home button to maintain TouchID. Some replacement screens you'll see available will have a home button pre-installed, which will function as a normal home button, but won't have TouchID.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Enriquezandy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 94
