Ga door naar hoofdinhoud
Smartwatch from Samsung released in August 2020. The direct successor to the Galaxy Watch from 2018.
Power Off option is popping up without the button being pressed
Not sure if this is the right forum but I'll ask anyway...
I have an issue where the Power Off option is popping up constantly on ky Galaxy Watch 3 Titanium without the button being pressed, essentially rendering the watch useless.
For a time I was still using it for activity tracking because when the screen timeout kicks in, the incessant Power Off pop up isn't an issue but then I noticed a significant increase in battery drain (Eg: Using 80% within ~ 2 hours.)
I'm about to dive in & see if I can find anything out of the ordinary; I'm thinking maybe corrosion on or around the home button pusher on the midframe but if anyone knows what is the cause of this issue &/or how to fix it, I'd be greatly appreciative.
Thank you.
Is dit een goede vraag?
Score 1
1 Opmerking:
Tried reviewing the right, sidebar questions? At least one will have disassembly procedures that may help, with views of the interior.
door
Voeg een opmerking toe
1 Antwoord
@smrtwtchcllctr use these guides Samsung Galaxy Watch3 to work on it. Clean it with a high grade isopropyl alcohol (nothing less than 95%) but watch the LCD. It may stain if you get any in there. Next to cleaning it, replacing the battery may just help as well.
Was dit antwoord nuttig?
Voeg je antwoord toe
Steven Bognar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 226
