Ga door naar hoofdinhoud
An economy SUV by Mazda, not the greatest sport utility vehicle in the world, just a Tribute. Made in the USA by Ford Motor Company. Simply a rebadged Ford Escape.
16 Vragen Bekijk alle
My 06 just keeps blowing number 3 coil pack
Need help with y this 06 tribute keeps blowing number 3 coil pack they did put a new pcm or whatever in it before they had me pick it up still doing the same thing. Anything will help thanks.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@rodneyweav60029 that is usually an issue with the PCM. Look through the online forums for the Tribute and you will see that Mazda had issues with that form the beginning. I would suggest that you have your Mazda's OBD scanned and see if it gives you a code other then the coil pack. Make sure you have some sort of guarantee from the shop that replaced/rep[aired your Mazda since it obviously did not work.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Codes
B1342-20 (ecu internal fault)
B1349-20 (heated rear windshield relay short to battery)
B1983-20 (left front door unlock relay control circuit shorted to battery).
Keeps blowing number 6 coil pack. Starting to think the customer had a bad new pcm installed.
door
Voeg je antwoord toe
Rodney Weaver zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 32
