Dryer stopping and blinking lights
My kenmore dryer will work for a few minutes then stop and the three lights will start to blink. I’ve tried pressing cancel and restarting but the same happens. I’ve also tried running it on different modes/times but it keeps happening
Is dit een goede vraag?
@mennayassin What model is the dryer?
door Andrew S
I am having this same problem with my kenmore dryer. Were you able to identify the problem and fix this? I would be grateful for anything you learned. thank you,
door Abraham Rice
I had someone come and diagnose the issue. Turns out it was the control board, and it would take 6+ months for the part to arrive. So I ended up buying a new washer/dryer.
door Menna Yassin
Try running it on air dry to eliminate or verify a heat related issue. It could be an over temp sensor or a shorted heating coil actually causing it to overheat.
door bill
