Ga door naar hoofdinhoud
Won't read disks at some points
So, a backstory on this. It's my dad's XBox 360, he recently gave to me. It runs a little slow, but perfectly fine. The only issue going on is that when I want to play a certain game, I'll put it in, then it'll just read for a second, then say "open tray" but if I put another game in there, it'll work perfect fine. But the issue isn't that. It's the fact that I can lay it on its side, and it'll start the game, but if I turn it off, it'll do this cycle and it makes me mad so much. If someone could please help me, I'd really appreciate it.
Is dit een goede vraag?
Score 2
1 Opmerking
Nu mai pornește
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@ravenlewis could be that the lasers are getting weak. Could also be the game itself. Since your Xbox works with other games, I would think it is the game. Of course, you can also replace the optical drive Xbox 360 Optical Drive Replacement but rememer there are special tricks because "the DVD drive works only with the particular game console it is installed in". You can transfer the controller board to keep the key.Check out https://www.youtube.com/watch?v=XuLOaX_C... for the How-To.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Raven Lewis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 44
Altijd: 1,603
