Ga door naar hoofdinhoud
9th generation of Chevrolet's full sized SUV, based on the GM GT800 platform.
2000 suburban engine going into 2004 tahoe will it work
im wondering if a 2000 suburban engine will work in a 2004 tahoe
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@nicholasru74706 it would have helped a bit more if you would have told us what engine size. In general yes, between 2000 and 2004 the engines should be interchangeable. There may be a few accessory brackets that may need to be changed etc. but essentially it will fit. It may not be a direct "plug and play" since you may or may not have to flash the ECU etc.
Was dit antwoord nuttig?
Voeg je antwoord toe
Nicholas Ruiz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 142
