Bad panel or main/t-con board
I have a samsung un65nu6070fxza that the picture quit working on. I need someone with more knowledge on tv repair than me now. At first the picture wouldn't come on at all, I disconnected all the cables, cleaned, and reinstalled with no change. Pulled off one side of the t-con cables and half the screen turns white and half black. Messed around with taping off the clock channels and finally got a picture back but now there's 3-12 colored lines on the left side. They seem to come and go but there's always at least 3-4, usually in the same spot but not all the time. With the clock lines taped off after about a minute or so the entire screen would have colored bars across it and flicker between the bars and picture. I took all the tape off and now it shows picture again with the 3-4 colored vertical lines and flickers between a picture and white and grey bars. I should also note that when it actually shows a picture all the brown cables on the driver board to the lcd panel are extremely hot and applying pressure/wiggling has no effect on the lines or picture. Any more troubleshooting tips would be greatly appreciated
Edit. @oldturkey03 my last post kept getting deleted for some reason but to answer some of your questions. Any time the picture is on all the ribbon cables on the driver boards get hot(with and without the tape on the clock lines). All of the boards look as they should, no physical damage or water damage/corrosion. I have pretty limited knowledge on where test points are on circuit boards unless it's painfully obvious. The tcon is integrated in the main board on this model but I tested the voltage on the cable that connects to the main board and most are 12v and one or two 3.3v. I also checked voltage on the driver board(one 1 of them have the test points) the vcc showed 3.3v when the picture was on then had no voltage when the picture went grey and white. I suspect the panel is bad and the main board/tcon is going into some sort of protection mode
Is dit een goede vraag?
