Im having error code ( LF) how can I fix it? Model MVWB300WQ1 Type 580
I have maytag washer machine but im having
Error code ( LF) how can i fix it please
Update (05/31/23)
Model MVWB300WQ1
Type 580
SR. C02170727
Is dit een goede vraag?
Model MVWB300WQ1
Type 580
SR. C02170727
Here's the tech sheet for the washer.
Go to p.3 to view the checks for an LF error code and also see TEST #2 on page 4.
If you find a faulty part, here's a link to a parts supplier that is useful.
Use the parts suppliers parts diagram for your washer to find the manufacturer's part number for the part (not the supplier's part number) and then search online using the manufacturer's part number only to find suppliers that suit you best.
Was dit antwoord nuttig?
Thank you so much for information. By the way any idea if there is video showing how to run the valves test?
I can't find a video on how to perform the test but p.2 of the tech sheet (see Manual: WaterValves (See ManualActivation,above) describes how to do it.
I can only find a video on how to replace the valves if one is faulty
Thank you i will check it
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 399
